B1 Homes Perth WA -Custom Design
Page 3 of 4
Can you corbel your verandah posts like the house to keep the scale even? If so what would the tops be finished with?
Gutters & Cladding completed
Plumbing rough in complete
Steelwork for verandah completed
Roof cover to start tomorrow 04.04.18 - 05.04.18
Plastering to start Friday 06.04.18
Measuring for cabinets is booked in for Monday.
Happy with the progress,
Looking good. Love your ceilings!
Kitchen
Laundry
Bathroom/Ensuite
Sinks
Baths
Showers
Freestanding Bath
Under-mount Sinks for Bathroom & Ensuite
Powder rooms
White set has been started
Your powering ahead with your progress, so much has happened. That ceiling looks awesome and the celestial windows will look fantastic. Rendering to the pillars and all your soffits and roof done too
Bahahhaha yes the spiders do seem larger in the country hey. The kids house a green tree frog bigger than the palm of my hand and I refused point blank to touch it
C-bus is becoming more comparable on price as the shift of the public move to z-wave based systems. C-bus have designed a module than can be connected to the net. C-bus is something you have to decide on in the beginning, so I have not gone with this. I am going with a fibaro system that allows me to expand at my own pace. The relays are installed behind an existing switch and still allow you to operate the light switch as normal. The home centre has many different plug ins available to allow different systems to talk to each other.
I have looked into Fibaro and its certainly the closest system which will achieve what I want out of the box which is essentially a locally based home automation.system. I had already marked down Fibaro as providing the relays. I just havent decided to go on the hub (due to its huge cost) until I try out OpenHAB. I already have a permanently running server so adding a home automation server on top shouldn't be an issue. Just whether I have the aptitude or desire to set it all up properly and have a functionign system
Good thing is being the owner/electrician, I get a construction Key!!
Deep Water (Taubmans) with Setler profile & Hafele handles
Stone to be statuario Venato
Falmec undermount rangehood (Inside roof motor)
Laundry
True white cabinets with zinc stone Essa stone
Ensuite & Bathroom
Internal Recessed Lighting
XDK 10 W
https://www.corsalighting.com/copy-of-l ... -j5w5o53m3
Garage Lighting
https://superlight.com.au/exterior-land ... d-12w-led/
Outside front exterior lighting
Pendants we have chosen
Will post some photos soon
Saturn zen they are best thing ever
Yes they are a clean looking switch....although we are using them for switches only, and some GPO's in the same range for the kitchen.
The rest of the gpo's & TV/Data will be just classic clipsal type
Laundry
Ensuite
Bathroom
3
ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your…
6/07/2023
3
Hello, we can help you please get in contact 0421019219 thank you
