Architecturally Designed Home - Vic
Page 3 of 4
starting construction end feb
designs and drawings all done, (no engineering problems, heh). the only change we made was the protruding white metal sheet upstairs and brought that back in to flush with the brick. did that purely on the basis of cost saving.
complete set is with our preferred building and waiting to get pricing back.
hoping to get started next month.
also, received all the imported stuff in one piece, very happy with the process.
made several design and engineering changes to accommodate budget
contracts signed, ready to start work straight after Easter.
will start posting pictures once major work starts.
very excited after 18 months since we started the journey!!
I'll be following it with interest.
Who is going to source the blackbutt veneer for you?
I'm planning to use timber veneer for kitchen/bathroom and timber for built in benches.
Will timber floors be compliant in the toilet/laundry? http://www.vba.vic.gov.au/media/latest- ... s-required
Have you purchased the appliances from the UK yet? IMO a 25% saving isn't worth it due to potential risk, lack of warranty and Australian approval for tapware.
Having said that, I previously purchased Grohe tapware from the UK about 40% of the local cost. The threads were smaller than std Aust size but my plumber was happy to fit them off using an adapter because it is a quality brand.
You may find that your builder/builder's plumber will not install them for you due to legalities, in that case you can fit them after handover.
Good luck with the build.
i did ask my architect about timber in wet areas and he said he's used it for previous designs as well and that it will be compliant to all applicable standards
in terms of the appliance, i received my shipment back in january. i understand the trade off with warranty, but with top end appliance, you'd hope it doesn't break within the first 12-24 months anyway. we thought it was worth the risk but each to their own. but in terms of adapters, we won't be using a generic UK/AU adapter, the sparky will chop off the end and put on a proper one. i've already spoken to the builder and he said it's fine.
With most appliance (and cars) faults it generally follows a bell curve, faults are found early, say within a few months, then will be fault free for a few years, then need repairs as it gets much older.
front garden all cleared for neighbour to park on:
roof tiles all cleared:
demo set to be done by next week, will post more photos then. additional stuff can be found on the blog: fnahome.blogspot.com.au
also, just to show how bad the garden was before
looks 100x better already
place looks 100x better without all the shrubs
front door gone to make way for the new master bedroom
Removed the balcony to bedroom 4 and (painfully) the hit and miss brick to the north as well as the protruding mesh screen. the screen is still there but it is now flush with the brickwork.
really didn't want to change them, but due to the amount of metal it saves, the cost savings was too big to ignore. below is the final floor plans.
finished demo and levelling.
almost done digging the footings for the slab. hopefully poured next week. unfortunately had to dig a lot deeper than we hoped so it's taking longer
few things we've had to change:
widening garage door
shortening garage length due to neighbouring tree's root, so we're putting in a shed instead that is accessible from the garage
section of fence replaced
front fence is going to be replaced
we are going to be away for a month so hopefully come back to see some frames/bricks up
Great to see you’ve been able to find solutions to the issues that popped up!
viewtopic.php?f=31&t=89059
I also received the first cut of my design and it is better than I expected. Still a few more iterations of design to get through.
did you end up going with the same architect as mine?
The slabs were poured in 2 stages:
garage brickwork has started and will be finished by next week, we have also received the first batch of steel beams (all the straight ones) whilst the curved beams will be delivered next week. in the meantime we can start the framing
2
I have posted this before: We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports…
3/03/2024
5
We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we…
18/09/2023
1
Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes.
