Modular Wall Systems is here to answer your questions!
Just to let you know that the team at Modular Wall Systems is now available to answer any questions you may have about modular acoustic & boundary walling options. As there is quite a lot of discussion about the modular wall system on this forum, we've decided to join the conversation and help answer your questions where possible!
http://www.modularwalls.com.au
View our profile on HomeOne: http://http://modularwalls.sydney.homeone.com.au//
Great timing! I am actually considering installing these.
There are a few requirements that need to be complied with in terms of look for the developer:
- we need to have 350mm x 350mm piers. I think the vogue range complies.
- we need to mimic a base at 350mm height and then have solid infills. This I am not too sure about.
Appreciate if you can assist with second requirement.
Also wanted to know if we consider to mix up the fence built with slats, do slats cost less or more than solid infills.
Appreciate your feedback.
Regards,
Our VogueWall posts are 250x150 and our EstateWall posts are 350x235, both wall styles come with a 75mm thick centre panel. Its a good question regarding your slatted features, some customers use a timber slat, however while timber is much cheaper it will fade and discolour quickly. Most commonly used are aluminium slats at 65x15 thick. Yes these are priced more per square meter than our wall system panels, it is not uncommon that your slats amount to nearly half your total wall amount.
We use a rough square meter of $250 to work out your slatted feature for the space in between your posts.
Hoping this helps you!
Kind Regards,
Gavin
Thanks for the guide on slat pricing. Can you also provide pricing guide on posts, wall panels, caps etc.
Also appreciate details on installation.
Cheers,
Ciao
Mark
I’m building/digging in shale.
