Door treads/sills
We're owner building a kit from Kitome and we're up to the doors. They have supplied the jambs for our sets of french doors and the front and back doors, but there is nothing for the tread (or whatever the bit along the floor is called).
I rang Kitome and they said that its designed that you just run your flooring all the way through under the door. But I can't work out or picture how this works at the edge or either the floating wooden floor or carpet. We've got the House Building Manual by Allan Staines, but it just shows external doors that have a sill.
Does anyone have and pictures or sections of how it all fits together? Or are we better off just going out and getting ourselves some hardwood to use there? We've got timber bearers and joists with a particle board flooring. The double french doors open out and the front door in.
Any tips or pictures/plans would be very helpful.
If they are well under cover you can run the floor under the doors (fine for tiles or solid timber but not appropriate for any other such as carpet or engineered flooring)
The alternative is as you say, to use a piece of hardwood as a 'threshold' under the doors. The jambs simply sit on top of the threshold or for a sloped tread they will be rebated into the top of the tread.
I'll try and find a pic
The french doors opening on to the deck will be exposed to the weather as there is only the eaves above them. The other set of french doors and the front door are under the veranda, but I think I'd still be happier with some extra weather protection.
This is the pic that is in my 4th edition of the Staines book.
I just hope we have enough height in the opening to fit a sill of some sort. If its not meant to have one it might be a bit tight.
If you had some pictures of different options, that'd be much appreciated.
Luke’s from Callala Bay, and I’m from North Nowra.
Looks like I draw the short straw.
Nothing wrong with Nth Nowra. Although Callala Bay is beaut, but not really a fair comparison
I'm there Saturday if you want to pop in
1
Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be…
26/04/2024
4
920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people…
