Window Size
Just curious, is the window size, say 600mm x 1800mm the glass size or the frame as frames differ in size, timber vs. aluminium, thin profile frame vs. chunky commercial.
Thanks
Andrew
Hi All,
Thanks
Andrew
Thanks
Andrew
All window sizes are stated as overall frame size, except most domestic aluminium windows (not EcoClassic) have an extra 40mm overall for the reveals (on the inside). So all brick openings are the same, internally, the timber house frame and plaster may be 40mm larger.
Ed
1
All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers.
20/07/2023
Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks
16/10/2023
Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design…
