Glue residue on window frames?
I have recently taken handover of a new house in Perth which has Jason Windows installed. The frames are powder coated in a silver colour.
Unfortunately some of them have a significant amount of yellow-ish glue residue from the black protective tape that they come wrapped in during construction.
I have tried to remove the residue using Desolv-it, WD-40, surface cleaner, and white spirits without any luck.
Can anyone help out with any proven remedies?
Thanks in advance.
If it doesn't work or takes too long, try "Un-do" (you can find it in BGS).
That said, we use a citrus cleaner.
Ed
In the end I tried Desolv-it and eucalyptus spray because it is what I had on hand.
I found that the eucalyptus spray worked well on the stubborn dried on glue, whilst Desolv-it was better on the fresher glue.
Thanks again.
1
Probably efflorescence Salts coming out of sand, cement products and mortar Water brings them to surface and when evaporates it stays Extremely difficult to get rid of
26/02/2024
1
Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon
29/03/2024
6
For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber…
