Increasing size of door after council approval
The current opening for the door leading onto the deck is 2100mm high by 3240mm wide. I am looking at a few catalogs and can see designs for 3 panel stacker doors that are 3400mm wide.
Do I need to go back to council to get approval for the additional 160mm or is it fine to make the opening a little bigger to accommodate.
Thanks PK
Tho saying that, it may not be an issue. Really depends on your council. Why don't you just ring them and ask?
All you need to do is make sure that the supporting beams are sufficient.
Ed
1
Hi Minho I have heaps of experience in Ku-ring-gai with both DAs and CDC ( this is the main area we build in). DA's are taking 12-18months and CDC's we have been doing…
20/07/2023
Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks
26/04/2024
2
Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra…
