Windows sized vs finished size?
The size's on the plans though I guess wont be the finished product. Is there a set size difference once they put the trimmings inside the window frames or how do you calculate the actual blind sizes with just the plans?
Curtain Wonderland's sale finishes this weekend and I was thinking about buying my blinds early.
No set sizes - depends on the window supplier... so don't risk it, why not buy conditional on nominal sizes on the basis that you will measure later.
Ed
you mean buy them but ask if i can return if they dont fit? i dont need to buy them now just thought if i could save a few bucks i may as well
hey ed
I suppose you could do it that way... But I think you will need made-to-measure, so I thought just do a deal to pay for a fictitious order in nominal sizes with a view to measuring to fit when the home is finished.
Or ask when their next sale is...
Ed
thanks for the info, i think ill just sit on it till the trims are done and go from there
the windows are sitting at the block, if i go and measure them will that be the final size, or do they put timber inside the window frame bit to make it look nice?
actually, am i getting confused?
Ahhh, sorry, I see. If the windows have reveals then this will be OK. Go ahead. Your window supplier should have the "over reveal" sizes, ask for this so you can cross check your measurements by subtracting 2 x 20mm from each dimension in the supplier's list.
Ed
if by reveals you mean the timber frame included with the window, yes it has these
Yes, the reveals is the timber frame around the window. Measure inside these for your blinds/curtains.
Ed
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
13/01/2024
Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some…
15/02/2024
Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier…
