gaps in rubber window seals
I just bought the property and found that there are some holes/gaps at the end of the rubber window seals on both side. Anyone knows if this will leak and how should I fix this problem? The property is about 11 years old.
Sorry forget to attach the photos
It is likely that it was stretched when it was assembled and over time it has shrunk.
It's a sill flap, used to push water away from the brick sill to prevent ingress. You can't seal it off, water must drain underneath, but you can make a makeshift version for the corners.
Hi EcoEco,
Thanks for your reply.
That means I can seal the corner hole with a silicone right? but I cannot seal the entire black rubber because water must drain underneath?
There are also some rubber which lift up a little bit, what should I do with these ones? Seal it underneath to make it flat?
And as long as you leave the remainder open, sealing that part pictured will be OK.
Yes, you can seal the corners, but only the corners.
Thanks EcoEco. I understand now. So the correct method would be seal part of the rubber is fine but cannot seal the entire rubber.
correct
Thanks so much ECOECO, when we seal the rubber, approximately what percentage should not exceeded? Like it’s better to not seal more than 25% or 50% of the entire rubber?
Seal the minimum.
Thanks so much😊😊
Seal the minimum.
Hi ECO, just got one more question. The door/ window has a gap with the wall, can I just seal it?
Yes...
Thanks Eco, so this one doesn’t relate to water drainage lol
Not at all...
Thanks so much.
I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside…
12/01/2024
5
Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much…
7/05/2024
7
yes that window needs a header, good pick up
