Can I use something different instead? Or do I need to find the exact type of rubber? (We are replacing the rubber in all the windows.)
Replacing the rubber seal - Aluminium Windows
Trying to fix our very old aluminium windows. The rubber is cracked and has tightened. I am not sure where to go to find a replacement (I did try Bunnings, but no luck).
Hi
How old are these windows & what brand are they? Should be on the pull handle.
The simple solution is to remove this glazing rubber on 2 edges of each glass pane at a time and caulk these with black silicone. I say 2 sides to allow the new silicone to cure for 48 hours before you do the other 2 edges. A tidy job and it will be waterproof too.
kaibis
4
Thanks mate, this helped a lot. Managed to get it back in.
24/04/2024
Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym…
10/05/2024
5
Whatever you do avoid Wideline and Stegbar.
