Pouring Piers Prior to shed slab.
I will be forming up and prepping the site for the concretes to come in and finish it on the day.
The slab details are 12 piers centers below C sections posts 300mm Dia 750 deep.
SL 72 mesh 40mm cover on a 100mm slab - no edge beam required.
What i want to know is can i have the piers poured separate to the slab and then do my form work following this and pour the 100mm slab directly on top.
I am considering this as due to the time frame between digging the piers and the boxing out ect for finishing and it would be desirable due to the amount of ground water around my place.
You mention groundwater, i would be paying particular attention to site drainage
I asked the question after reading the notes as the plan mentions pier depth of 750 if poured separate to slab. Not clear if that is meaning that the piers as a footing for the posts ect and infill slab later or as i mentioned above the slab being done right on top.
I would have expected some form of rebar would be needed in the pier to attach to the slab mesh.
Its a shame the Slab detailing is just a generic one from a shed supply company. Is it something the building surveyor from local council can clarify also do you think?
You need to understand that M class site can be ruined through poor drainage and become "P"
Design 1 included edge beams with trench mesh and SL82 throughout 110mm slab depth and the pires under each post
Design 2 no edge beam, slab is 100mm with SL72 and the piers reduced by 100mm in diameter.
Though it was odd to see the difference and have done some building design study over the years (never finished my diploma and went into electrical design) but with the background in engineering makes me cautious about the revised design and think its with the extra expense of the trench mesh and SL82.
You need to remember that if your base is poor or damaged through poor drainage your slab may fail and crack.
The extra cost of materials is minimal but the risk of failure is greater with slimmed down design.
Regulations are about minimum acceptable standard, nothing stops you from doing better.
One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the…
14/03/2024
3
Old Home Restoration / Renovation
could be anything but it looks like styrofoam
7/05/2024
I am building a new residential house. The structural engineer suggests drilling 60 bored piers which are no less than 600mm deep and at lest 300mm in stiff clay. If…
