Exposed aggregate -question
I've just had exposed aggregate poured and wash happening tomorrow.
Are a few small surface holes typical?
And what should I check that concreter uses in the couple of gaps I've seen between he expansion foam and house to prevent water entry?
I've read about proseries multipurpose sealant, sika flex ... but confused as to what is best for this.
Thank you in advance
Knowing what is normal is so helpful.
The surface holes that remain today post wash are small.
I don't think they've used the peel off type of foam. So will ask if they use sealant all the way around once they cut top of foam.
And will get them to use peel off type for sides of house.
Thanks again
Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired…
24/02/2024
After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly…
