Colouring Driveway - Best Option?
If I want to pour a new driveway and want it to be coloured (e.g. Gunmetal) I understand there are two options.
1. Pour regular (grey) concrete then apply a coloured sealer on top
2. Use a colour mix with the regular concrete and pour that.
What are the pros and cons for each and which do you recommend?
more expensive but worth the money.
You should end up with a consistent finish (color wise) and if it does get damaged it won't show grey through
But if the concreter is worth the money they are charging, they should now this and specify the mix to allow an adequate strength (specify a different/stronger mix) and compensate.
Adding reo and placing control joints correctly would also help I imagine.
Apparently, if they use liquid colours, there is no problem with strength. But ... I can't remember which of the "colour" companies makes these liquid colours
Like I said, if the concreter is any good and knows what they are talking about, then they will be able to specify what changes need to be made to the recipe/formula so that it has a minimal effect.
If you are concerned, perhaps extra thickness would be an option?
It would mean more concrete and thus more cost, but I think they recommend 150mm for heavy vehicle parking so perhaps that would compensate for any weakening of the mix?
Newbie question for flooring options. We are thinking of changing the flooring for bedrooms and passage area. Last time we looked at flooring options was almost 8years…
7/04/2024
1
Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks
24/09/2023
4
Using a rivet sounds like a good idea thanks
