How to seal concrete floor?
We have just moved into our new house and the floors are yet to be done. The white sand and dust from concrete slab is spreading every where. We are waiting for laminate floors to be installed. Is there any way we can apply a sealer to keep the dust off.
Cheers
Tama
This is only a temp solution. Where as the epoxy described earlier is more of a permanent solution. But it will be more expensive i am guess. A wast of money if you are going to cover it up.
However, if you use an epoxy curing compound you can direct stick engineered flooring on plywood or T & G boards,and will protect your timber floors permanently.
I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old…
16/07/2023
4
Thanks mate, this helped a lot. Managed to get it back in.
