Tank Slab
Can someone tell if this is strong enough to hold the weight of tanks + water or should i go 150mm thick slab which is going to cost a lot more.
Thanks
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
9/11/2023
7
Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I…
15/01/2024
7
Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It…
