Cooling/heating with Whole house fans / home Economisers
Does anyone have any experience with the whole house fans or home economisers?
Ideally as I have HVAC im curious if there is any Australian Home Economisers that integrate with the HVAC as there would be a cut over point when indoor outdoor temps don't benefit the Economiser and HVAC must go on.
Thanks in advance!
What sort of system do you have?
What sort of thermostat/controller are you using?
What sort of house do you have? (single/double storey, brick veneer/ timber cladded, etc)
Looking to kdb 2 storey and planning on the most efficient HVAC and if cost effective incorporate an economiser (if possible and viable)
I'd also be looking to add the NEST thermostat that will also tie in with ceiling fan.
I'm hoping that the combination of ceiling fans and economiser reduce the time the HVAC needs to be on, this reducing power bills.
Thoughts
You'd require a separate economizer thermostat/controller which would control a couple of fans, one for fresh air supply and another for spill/purge and volume control dampers and also interface to the Daikin control system to inhibit heating and cooling stages when in economy cycle. That's the rough overall gist of how it would work without getting too nitty gritty.
I'm not too much a fan of the Nest thermostats but to each their own.
My suggestion would be to engage a mechanical engineer/consultant as part of your works to look over and design you a system with optimal efficiency and the greatest power saving.
hth
That's starting to sound uneconomical in a home environment.
Possibly a vented skylight with rain sensor (for automatic closing) being the highest point on the ceiling might provide adequate convection to release internal residual heat.
I think i finally found the thread you mention. Is this it?
viewtopic.php?f=20&t=82255&hilit=draw+cooler+outside+air
Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for…
14/02/2024
Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator…
13/05/2024
3
Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is…
