In wall insulation
We are building a house in WA and just wondering is it worth paying extra for inwall insulation (between bricks)
Cheers
So by itself, double brick is not a very thermally efficient method of construction. I'm certainly not a fan of it, but it is very popular in WA.
Insulation in the cavity definitely improves the situation, so I'd recommend it. It will thermally separate the 2 wythes (layers of brick). The outer layer will still be heated by the sun, but that heat will struggle to penetrate through your insulation, & through the inner layer of brick, into the house. Importantly, the thermal mass of the inner layer of brick is now very useful at regulating the temperature inside your house, knocking off the peaks of the highs & the troughs of the lows. Absorbing heat when the brick is cooler than the surrounding air (in the hotter part of the day), & releasing heat when the brick is warmer than the surrounding air (in the cooler part of the day). So internal brick evens out the temperature throughout the day, making it slightly cooler in the day, & slightly warmer in the night.
Foil (with an air gap) is a great idea as it reflects the sun's radiation. So it's a good idea anywhere that receives a lot of summer sunlight. Particularly on the western wall. This side of the house gets blasted by summer sun in the hottest part of the day, so is the most important aspect to look at. Hopefully you have decent length eaves, which will shade the northern side of the house from summer sun.
Beazley77's absolutely right. Along with improving the thermal performance of the construction method you use, you should also consider the orientation of your house. It makes a huge difference! "Passive solar" is the term. In simple terms, what it means is ORIENTATE YOUR LIVING AREAS TO THE NORTH. This side of the house will receive sunlight into the house in winter, warming it, but will be shaded in summer (when the sun's higher in the sky). Limit windows to the west as it's blasted by the summer sun (& locate rarely used rooms here, like garages, laundries, bathrooms). More can be found here,
http://yourhome.gov.au/passive-design/
I'm in Sydney, in a very well designed apartment. It's currently 12C outside, but sunny. Inside, in the living areas (which face north) it's beautiful, warm & sunny. Heating is never required in this place! The bedrooms (which face south) are very cool, but shut off from the rest of the house. They receive no direct sun in summer, so remain cool.
Passive solar FTW!
Hi all, Just wondering if anyone had suggestions on installing/replacing wall insulation on an external wall which doesn't have wrap, our miners cottage being constructed…
26/01/2024
Hi all, I’m in a house built 7 yrs ago. One bedroom wall faces East and gets strong morning sun. It’s a gyprock wall with hebel exterior. One section of the wall,…
