Daikin outside air system
It would seem to be pretty effective in Perth when the seabreeze kicks in.
The cost to upgrade to it quite high though, $500 for the controller(E-Zone to MyAir5) and another $1550 for the system!
Any thoughts appreciated.
If you're really interested in this sort of idea why not go with an evap combined with splits in the bedrooms?
However, in most of these cases, just running the A/C will bring the inside air temp to at least as low as the outside temperature fairly quickly. Then after this, you get no thermal benefit from the outside air intake. Say this takes half an hour, with the A/C running at 15kW (5kW power draw). During that time, you might get away with only 10kW (3kW power draw) if you could instead draw on the cooler outside air. That means a 1kWh energy saving per instance of this. Then say these conditions happen 30 times a year, then you might save 30kWh a year, or around $10 a year. At that rate, the economic payback is only going to happen if the unit costs less than $100 to $200 in total.
I think those estimates are generous though, because a nice sea breeze outside might actually be 28 degrees, which may still be hotter than that stifling 27 degrees inside temperature - which just feels hotter on account of less air movement.
I kind of like the idea, but I don't think the economics stack up, especially when you can open up windows to get a similar effect.
We've just finished a build with a good amount of insulation added for winter.
We have a lot of glass to the North for winter. Now that the sun is getting lower the living area is warming up. The house has been designed to allow good cross flow from windows. However if there is no breeze there is no cooling. Once the temp cools in the evening the house remains warm all night due to the insulation properties. Putting the ceiling extractor fan on in the ensuite helps a lot to pull a nice breeze through the bedroom window and thus cooling the room down.
I think fitting an outside air inlet or outlet will have a lot of merit at our place (Adelaide)
Ceiling fans aren't really an option as we have standard 2400 ceiling height, again for heating efficiency.
Using the ducted air con system to bring in outside air is unlikely to have any significant effect as the air velocity is very low, and in the absence of conditioned air you need the rapid movement of the air to have any cooling effect (cooling effect is the air moving past you and your perspiration makes it feel cool)
I installed an air transfer kit at our last place to transfer hot air from the wood heater, heated living area to the back of the house. It worked a treat.
I think I'll look for a large inline fan and run it independently as required.
The question is how large, it would have to be of similar flow to an evapcooler for 3 bedrooms or the living areas.
Seriously, your best bet is ceiling fans for economical air movement (work fine with 2400 ceilings). The other option is an evaporative cooler which would work great in the dry heat of Radelaide
We live pretty close to the beach so we get the sea breeze pretty early normally. so the whole idea of using the sea breeze was pretty attractive.
I think our money might be better spent upgrading to a premium inverter.
I am thinking (possibly overthinking) about this topic for a 2 storey home!
1. Extraction of hot air, using the AC return Duct (a.k.a Home Economiser)
2. Distribution of Fresh 'Cooler' outside air using existing AC ducts (some call it Ventilation mode)
3. Incorporating to switch over from Ventilation mode (cooler External Air distributed by HVAC fan) to AC mode (where the HVAC Compressor is active) depending on external temps and desired internal temps/humidity.
I hear that its common in Commercial systems but not in residential.
Has anyone actually got something like this?
Cheers!
3
Yeah sorry man, thats always been my fear during this first time build.. we have literally just hit lockup as-well, so ive been praying for no issues. Our mortgage /…
17/06/2023
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
