I'm building a new home and am installing a geothermal system. What kind of questions do I need to ask when getting a bid?
Thanks, John
Geothermal System
Thanks, John
I'm using an earth tube which is purely some PVC pipes under the house, to provide some cooling during late summer afternoons. Warm air is drawn from outside (or recirculated from inside), cooled as it passes through tubes beneath the house and then enters the ends of the house. It's just one of a collection of measures I'm using to keep my upcoming house between 20 to 26 degrees all year round without any air-conditioning or heaters.
Where are you building?
Ie what is the need of heat and cold?
And have you priced the geothermal system costs in Australia.
As casa says they are an efficient air cond system that uses the ground to cool of heat the water in the pipes - but typically our climate is not as severe as that of say northern USA.
So just check that bang for buck it is cost effective.
I saw plans and photos of a house the other day that in Adelaide is using full solar heating to warm an underslab heating system, simply by tripling the number of roof collectors and a very large water storage tank. Cost to run it - minimal. The sun does most of it.
Steve
Do you have any details or a link to the solar heated house? I'm planning on 12 m2 of extra hot water panels to provide in-slab hydronic heating.
I'm doing the top level design and any information would be very usful.
Cheers,
Casa
2
It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and…
16/04/2024
2
the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you…
21/09/2023
2
Thanks for responding. Do you know of anyone installing this product in Sydney?
