Implications of 900mm eaves
Likely we will go with a custom builder - I am trying to understand the implications of choosing 900mm eaves instead of 600mm or something smaller. Intent is for the eaves to provide summer shading from mid-November to mid-March. We would like to maintain a roof pitch of atleast 22 to 25 degrees (lots of solar PV and solar hot water).
Has anyone recently done this with a builder in the Sydney area? What are the cost implications? Can we get a higher roof pitch and the 900mm eaves (future expansion area in the attic)?
(Our designer is suggesting we keep to 600mm eaves)
At the end of the day, just about anything can be done if you are prepared to pay for it.
Any advice from anyone else who has considered this cost or has gone through with it?
My previous build had 1200mm overhang and a tiled roof. This required serious rafters i.e. 300mm deep rafters.
What is your stud height for each level - 2440 mm ?
Stewie
Stewie
Bit that's confusing me is why does the wider overhang have to mean lower eaves? Can you not have wider overhang (eg 900mm eaves) AND higher pitch (say 25 degrees)? Feel like I am missing something in my understanding.
Actually, a lower pitch would give you higher eaves...
The detail is a standard brick veneer house with a floor to ceiling ht of 2700mm, a roof pitch of 25ยบ and the usual way a trussed roof is fixed to the timber frame.
The first here shows a 450mm eaves overhang leaving a floor to eaves ht of 2350mm
The second shows exactly the same but with a 900mm eaves O/H leaving a floor to eaves ht this time of 2145mm
The third is a non-standard way of doing the trusses where the bottom chord of the truss goes all the way to the fascia. Doable but not how they are usually done and I'd bet a fair bit more expensive due to the fact that the bottom chord would be taking most of the roof load plus it would have to be beefed up considerably. You would also end up with a higher ridge ht compared to either of the other two examples.
Stewie
Have you had a look at the solar orientation thread on these forums? Lots of info there too. I think I've posted up a couple of drawings similar to 1960'sMHomes above in that thread as well.
viewtopic.php?f=31&t=55057
and passive solar buiulding in Sydney
viewtopic.php?f=35&t=71561
Stewie
5
My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance >
7/07/2023
7
Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out…
22/12/2023
4
The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's…
