Hot water system - normal operating sound?
Is this the normal sound this unit should make? I can sometimes hear it buzzing inside the house. In the last video, you will see how I change the 'setting' from 1 to 3 and back. This has been going on for around 2 months.
https://www.dropbox.com/s/ywuhwygy9jfth ... 100034.mp4
https://www.dropbox.com/s/eij6x8hnnodog ... 162646.mp4
https://www.dropbox.com/s/3kzfcg3j8v1yl ... 095403.mp4
https://www.dropbox.com/s/llduhr9bxyfge ... 095509.mp4
Stewie
-G
Thanks. Just concerned as that noise started 10+ months after it was installed. So it hasn't always made that noise.
-G
-G
If its 12 month warranty that sounds about right ...
I remember in one house (older) we could never hear the shower or hot water in other rooms. In the newer places you seem to get the noise more. Is this due to less insulation etc ?
2
the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you…
29/04/2024
7
For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours…
6/09/2023
I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be…
