Heating and Cooling
We would like to know what would be best for heating and cooling. Do we get something that can be used for both?
We are in Victoria.
Thanks,
A lot would be dependant on how much of the house you wish to cool / heat simultaneously. If it is only 1 or 2 rooms then I'd say hi-wall split systems (reverse cycle) if more than that then the options basically are
Ducted evaporative and ducted gas
Ducted gas with add-on refrigerated cooling
Ducted reverse cycle (refrigerated heating and cooling)
Hydronic heating
Underfloor heating (in slab)
Wood fire
etc etc etc
There are many, many options available. First determine how much of the house you would want to both heat and cool simultaneously. This will reduce options and allow you to focus on the options remaining.
Gas ducted should cost you less, unless its a poorly designed system, you leave the doors an window open or you are getting either a really great price on electricity or a bad price for gas.
reverse cycle electric heating uses a lower number of units compared to gas but the rate for electricity is usually about 3x gas so gas is cheaper.
If you went electric, I would go for reverse cycle splits so that you can minimize the rooms you use it in at once. That will help you keep the cost down.
For cooling.
I don't know if you can zone evap.
If you get refrigerated, get zoning. It'll help you keep costs down, so you don't have to run the whole house at once.
Get an extra return air section if you have a large house.
Consider ceiling fans in all bedrooms and living areas as well. Fans cost around 1c per hour to run at medium speed. They will help on hotter days and negate the need to run AC on warmer days where fans will do the job.
I plan on using my air conditioning like my insurance. Not unless I have to.
Also look at insulation upgrades to help stabilize the temp and stop heat loss/gain.
Compare the amount of gas used vs electricity vs tarriffs!
It has been a sales pitch for refrigerated systems for YEARS - more efficient but NOT cheaper (and I am a fan of refrigerated systems)
Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for…
14/02/2024
Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator…
11/03/2024
2
I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major…
