Ducted circulation and dust
My wife has huge issues with gas ducted heating and dust. It sends her into a sneezing fit. Even our current rental which was only built 3-4 years ago sets her off, and I can smell it too and have the odd sneeze.
For the house we are trying to (!!) build we have done a reasonable passive design with good insulation and are considering, for the heart of winter, a woodheater and possibly reverse cycle split system (for when the "can't be buggered" syndrome takes hold). But then, we thought, we may need to duct some warm air from the living areas to the sleeping areas.
If we do that though I suppose there's no reason why we shouldn't suffer the exact same dust issues as with ducted heating!
Or is there?
Thanks for alerting me to the dust issue. On Friday I've talked about a heat shifter (that's the "official" name for it) to a bloke from an A/C outfit, who's allegedly designed/installed it before. I haven't asked him about filtration, but I will on Monday. It's most likely possible to fit some sort of dust filter into such system. Will let you know what he says.
Chris
In the meantime I've been reading about setups people have with no fan, just the duct and allow natural air flow to take place. I'd imagine these would be better in terms of not stirring up the dust! But probably not as effective at shifting heat.
Thanks kris, looking forward to hearing.
The non fan ones really don't do much
We have ducted evap aircon and have no problem with dust, he would suffer so much tho if it was gas heating.
As the AbPstr said, could it be more a gas issue ? sounds like it may be bringing on allergy symptoms. Would you think of having ducted electric reverse cycle instead of the gas?
Chris
Still, perhaps the temperature of this is higher in a gas heater vs an A/C one and as such alters the properties of the dust as it cooks it on the way through?
I popped on our wall mounted split system this morning (house temperature 14 deg) to avoid setting the missus' sneezing fits off.. and she comes out and turns it off.. "can't stand the noise!!"
all our friends with wood burning heating ditch it and use something else after trying it
mess
smell
constantly stoking
what about hydronic wall panels???
I would love them... but can't afford them
5
the leaves that are now underground go yellow, the tips that poke through photosynthesise and have chlorophyll, same reason they grow rhubarb in the dark.
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),…
