Hi All, i'm building ATM & just about to put the roof on. i've had an idea that with the instalation of a large tile fire which has oven component & HW jacket for our winter, there will be sufficient heat that i could move some heat around the house to bedrooms in cold weather. i had the idea of puting several independant extraction fans in the ceiling over the tire fire area and pushing air thru ducting tubes to the bedrooms....has anyone done this type of thing - any ideas would be appreciated.
cheers tony
Ducting warm air around home
cheers tony
https://forum.homeone.com.au/viewtopic.p ... +fireplace
you may have to wade through the OT stuff...
the other component i'll have to use, regardless of ducting r 3 ceiling fans to circulate the heat out of the vertical pitch of the cathederal ceiling.
hope that gives u another perspective to this idea. imo huge amounts of heat r wasted up on the top of ceilings!
cheers tony
Hi kexkez, the reason why i'm going to use a fan, either at the point of extraction - ie on living room wall (we have a section of verticle cathederal wall) or a fan " inline" on each duct is becos hot air rises and while that air may enter the duct, it will just "sit" in the duct and in the top few inches of the room its going to. by puting a fan in, the air get pushed down into the room its going to.
Yep...that's what my mate in Sale found...he's got very high ceilings in his country house and needs the fan to operate. Nomush...just enough to move the air.
Yes:
http://www.westaflex.com.au/_pdfs/venti ... _Pages.pdf
Add more ceiling fans as required to push hot air down.
Just an update from that topic that Mike posted earlier. We decided against going with a heat transfer system on the advice of an independant heating adviser. I can't remember his reasoning for advising against it though...too many things to think about since then
Not much help really, am I.
Good luck
Somehow I've missed this thread before now. The great minds think alike
Chris
5
Thanks chippy, Budapest for your responses. We've gone with aggregate > I totally know what you mean about the ants here in Perth, they are a pain.
5/08/2023
2
Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not…
20/09/2023
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
