Green glue
Was looking at resilient mounts etc but alot of time and effort to do.
Any feed back from people who have done similar would be great.
i have just started looking into soundproofing my home ( 2 increasingly lound teenagers) and greenglue and some cost effective combination of boards looks the go. How did your installation go, what would you recomend
Cheers Bill
Chris
http://www.greengluecompany.com
Its a soundproofing compound like liquid nails but has soundproofing properties
Its mostly used in home cinemas
layers being timberstud with rockwool + resiliant channel fixing = plasterboard layer 1 + greenglue + plasterboard layer 2
http://www.acoustica.com.au/quietwave.html
http://www.abc.net.au/tv/newinventors/txt/s2423228.htm
theres also lots of products on the market, i guess its a matter of how $oundproof you want
Decoupling (like the resilient channel mentioned earlier)
Absorption (simple insulation)
Mass (the plasterboard is the best all around source for this)
Damping (visco-elastic materials)
They all perform different functions, and none replace the other in an application. Ideally for high level isolation, all 4 elements would be deployed.
The thicker board has more mass, and is therefore better for sound isolation.
Any new product that hits the market needs to have significant acoustic testing. Beware of claims that have no corresponding lab tests to substantiate.
1
Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon
