Building ForumHeating, Cooling & Insulation
Underfloor insulation options for timber sub-floor
Hi all
Currently working through an extension and was talking with the builder and carpenter about subfloor insulation options.
Subfloor consists of 140mm joists with 90mm insulation batts planned to go between. Is there any advantage to increasing the insulation thickness without doing anything else? Other options i've thought about:
I can add the membrane myself after the fact, although the chippy likes the idea of doing it straight up so he can use it to lay on while installing batts first.
Is there a superior option out of all of these?
Thanks
Sub divison with Zero lot ( maintenance easement )
Hi All Property : 25M frontage and 30M depth, total…
26/03/2025
2
Timber floor finishes - Jarrah
Flooring & Floor Covering
Thanks for your reply, Michelle! The water staining is a big worry, and since the kitchen is timber floored and the bathrooms exit onto timber we just know the floors…
24/07/2025
4
Slab v timber floor system
I have seen many heavily engineered slabs that probably should have been timber floors.
