Block wall cost
I am looking to have a small block wall installed at the boundary. The height of the wall will be between 600mm to 800mm and about 15m in length. I'd like to have concrete footings poured also. How much should I be looking at roughly for this (is there a general /Im or /sqm rate?). I expect there to be a little excavation and there is space for a kanga.
Thanks,
SS
Footings - roughly 250x600x15m=2.25 cu*$260=~$600 for concrete, $300 for reo and around $1000 for labour including excavation.
Plus pump cost for two pours (may be around $600-800 per pour).
So roughly around $5.5K+GST.
But Besser blocks reinforcement + footings reinforcement needs to be specified.
The footings will be likely be 1000 wide though, not 600.
Generally engineering certification is required if the wall is above 1 m.
My council requires them above 600. Just sayin.
1
there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel.
15/11/2023
3
Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks
7/03/2024
4
Thank you again Simeon.. I will call my certifier for that. Have a good day
