Retaining Wall to boundary or offset?
This is my first post. We have recently purchased a vacant block of land in an existing residential area with houses on both sides. The land slopes downwards from left to right about 2metres across the width of the land.
We know we will need to cut and fill to create a flat building pad and require retaining walls on both sides (up to 1m).
My question is, can the high side retaining wall (the one that will be exposed) be built right to the boundary and line up with the fence that currently divides the two properties or will it need to be offset half a metre or so to allow for drainage etc.
In new estates, there are large retaining walls between properties on the boundary, but just now sure if feasible in the existing residential area.
Thank you
The post in Mar 2017 really shows the retaining walls, but there are various pics throughout. Hope this helps.
www.tashandpaul.wordpress.com
I was also looking in fence brackets for retaining walls but I cannot find something that is 200mm offset.
Stewie
8
Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney?
3/12/2023
Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will…
8/02/2024
4
Yes, I had already tried searching those. In the end I am fabricating my own.
