Build over Easement dilemma, Any Suggestions?
Solution 1: steel post boxed with blue board as Pilar and wall, then render. Pro: cheaper and easy Con: May be easy to move and crack.
Solution 2: Steel post boxed with light weight Hebel blocks, then render. No sure cost wise, Con?
Because it is a curved wall inside the court, make it more complicated.
Any other possibility? Many thanks!
Cheers
Gary
2
You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work
15/08/2023
1
You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not…
24/01/2024
3
Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings
