Lilly Pilly dying in same area
As you can see in the image the Lilly Pillys on the left and the right have grown well but towards the middle they get shorter and the ones on the centre don't grow at all and keep dying.
It just looks silly and I would really like to have it look like a nice even hedge all the way along.
Can someone please help me understand what's happening.
I'm an armature when it comes to landscaping and gardening.
Thanks
Today https://drive.google.com/file/d/0Bz5dHW4cxWAddlRHSkpsR2U2bTQ/view?usp=sharing
Two years ago https://drive.google.com/file/d/0Bz5dHW4cxWAdYmpoRUNBaVl6MFU/view?usp=sharing
A soil test is simple. Check pH, and check if the soil is hydro phobic.
The pics aren't showing. But anyway, there's either a problem with the soil or grubs that are chewing the root system.
Thanks, I put the direct links into the post now.
Is this ph test kit from Bunnings what i need? https://www.bunnings.com.au/manutec-garden-care-products-soil-ph-test-kit_p3016727
Alternatively, you can get professor Mac's 3in1 which will help kill grub, and improve the soil. Molasses and seasol wouldn't hurt either. But if pH is wrong, all these things are pointless.
But let's start with the pics.
Damage from a mower or line trimmer?Heavily compacted soil?
Check the PH
Check for compaction
Check for water logging, could be a possible broken pipe- soil usually stinks if you dig down.
Check soil type, does the area have soil or buried building waste consisiting of concrete, rock, gravel etc.
If you have irrigation make sure it is working on the problem tree.
If it was pests all the hedge would show issues. Same goes with nutrients. Although the tree may lack nutrients due to the soil not allowing the plant to absorb them.
CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.…
11/09/2023
3
Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon
