Anyone built their own retaining wall?
- Loose stacked concrete blocks
- Treated pine posts and sleepers
- Core-filled bessa blocks on concrete footings
- Poured concrete
The easiest was the loose-stacked blocks as bashworth mentioned. They look good, and are easy to fix if you get any movement. The downsides are they aren't cheap, and you loose more land than the other types due the setback slope they have.
The wall I'm most happy with is one of the core-filled bessa blocks ones. It looks good, doesn't take up room, the fence is mounted up close to it at the top, and it's still dead-straight after several years. At 1.2m tall, it had to go through council on the house plans, and have engineering on the footing size and reo details. The construction is a bit involved, but nothing too difficult, though it helps if you can get a concrete truck right up to it to pour the footing - oh and the core-filling: that's the painful part.
Formed up concrete is quite cheap and strong, but doesn't always look the best if its going to be visible. The formwork can be a fair bit of cost and work, and needs to be strong to support the concrete and not bow.
The treated pine walls are fairly cheap and simple, but can easily look scruffy and I don't see them lasting well into the longer term.
Have a peruse at my build. Both timber and dry stack masonry walls in my thread.
viewtopic.php?f=19&t=44663
I've done a couple of treated pine walls, not too hard unless the digging is hard. We ended up giving up on digging at a mates wall building party and he got a mini excavator to dig the post holes there was so much rock there. Cheap and easy. One wall I was given a rough quote for at $12k but ended up doing for under $1k in materials + a BBQ for the labourers.
I've also fixed up a besser block wall that fell over and that was a bit more involved with mixing mortar etc.
3
Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful
7/03/2024
4
Thank you again Simeon.. I will call my certifier for that. Have a good day
7/07/2023
1
Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You…
