What do you put under a raised deck to prevent vegetation?
...if I'm going to be building a raised deck at the back of our house, with the posts in the ground set in concrete, what should I put between the posts to stop vegetation growing up through the deck boards?
Thanks
Simon
Simon
As above, weed mat works.... and makes crawling underneath to fish out tennis balls that little bit more enjoyable...
and jewellery that always manages to finds its way through the gap between the wood.
Weed mat is a good idea.
Pet rabbits
miniature sheep
Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick…
7/05/2024
I am building a new residential house. The structural engineer suggests drilling 60 bored piers which are no less than 600mm deep and at lest 300mm in stiff clay. If…
22/05/2024
5
thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you…
