Damaged Retaining Wall and Fence - What do you think?
Its up to the wall designer to understand what the possible loading may be and that includes machinery on the soil when the soil level is at the top of the wall.
So with outward pressure that would mean the wall need to push against the post, not away from it as in this case.
That wall is only as strong as the fixings holding the wall to the posts!
How long they can do that will depend on quality of timber and quality and strength of the fixing.
Surprised the wall hasn't come away from the posts already.
Its pretty straight up and down too for a wall that height.
Its built back to front in other words.
I also agree with Fu - the wall is backwards - the posts should have been on the other side.
As you constructed the retaining wall, I would say the onus may fall on you.
Did you seek engineering advice prior to retaining wall construction? Perhaps you have recourse there?
As mentioned previously, our issue is with the way the soil was moved, and the fact that even though the driver was told by the SS to stop work, he seeked out our opinion and then just went on and did what it was he wanted, with no regard to the damage that was being done. As you can see by some of the other pictures, the rest of the wall is fine with the volume of soil as it was not constantly being driven over. Had the driver stopped when asked, by both the SS and us (when the damage was noticable) then we wouldn't have had this problem.
Is there anyone out there that drives bobcats that would be able to give their opinion on the way the soil was spread? We are trying to find out as much as we can before we meet the SS on Tuesday and discuss it. If it is our issue, then we will take responsibility, but if it is because of the way the driver spread the soil and also the fact that he continued on after strict instructions from the SS to stop, then we think he should be held accountable.
Thanks for reading.
The responsibility of the wall backfilling, belongs to the person who constructed it, not the bobcat operator, whoever built it should have been there to supervise the filling.
You mentioned in your first post the wall was constructed "as per standard practice", I would be interested in seeing that standard.
Where did the backfill come from? Looks like it doesn't belong within 100m of a retaining wall.
What form of drainage did you use?
If it were me I would eat some humble pie and have the entire wall replaced, before you proceed with any landscaping, as it will be cheaper and less disruptive now than in 5 years time.
Was there pictures to this post? Where did they go??
Yes, there were.. It's a shame the OP took them down, as even though he/she may not have agreed with the responses it was a good lesson for all prospective wall builders.
We have had a meeting with the builder and he will be speaking to the bobcat driver when he gets back from his holiday. I will let you know the outcome and put some pics back up when I get time.
Thanks again for your suggestions.
You say the wall was built with an engineer, did they not specify backfill requirements and was someone (the wall builder) there to supervise the backfilling ?
2
get some pool noodles and then bark mulch over the top
7/03/2024
4
Thank you again Simeon.. I will call my certifier for that. Have a good day
