HELP! Blocked storm water pipe under liquid limestone
I'm half way through a backyard landscaping project and have realised that a storm water pipe is blocked or damaged, causing the downpipe to back up with any meaningful rainfall. The problem is, the pipe is now covered by liquid limestone making repair difficult.
Pic here: http://img204.imageshack.us/img204/6964/img0017small.jpg
I've had a roof plumber out but he was unable to unblock it (even after hacking a nice hole at the bottom of it). He suggested that I'll need to cut up the limestone to find the suspect pipe. Not happy with that idea, so I've come on here to hopefully come up with an alternative.
By the way, all stormwater pipes at my place connect to a common stormwater catchment (group of villas) and not soakwells. I've poked some hose down the downpipe but can't tell which way the pipe heads underground.
Ideas I'm currently tossing around:
- Tunnel underneath, find the storm water pipe, connect a new joint and run the pipe to a new soakwell. Sounds good in theory but I'm not sure how to tunnel without impacting on the structual integrity of the liquid limestone. It would also need to be a big enough tunnel for me to crawl into in order to make connect up new piping.
- Move the downpipe towards the window and allow the water to run across the limestone onto what will soon be grass. Or, as an extention of this idea, install a drain between limestone and grass which would capture the water and run it to a soakwell.
Any thoughts on these ideas or any other creative solutions would be greatly appreciated!!
Steve
I can't see any alternative but to cut out those two slabs of LL and fix the drainage problem. Dont know about the idea of running to a central drainage system, I'm guessing that tree roots have found the drainpipe somewhere and have expanded into it which means it will always have a problem.
If you cut out those two slabs you could install a soakwell or ag pipe under the lawn and drain to that, that way they are accessable. When reassembling use a drain grate and have your downpipe stopping above it so in a flooding situation you wont have water in your eves.
Those two slabs would be easy to repour as they are basically formed up for you. LL is not difficult to do. PM me if needed.
I've spoken to the limestone guys (they only poured it a month ago) and they recommended trying anything before cutting and repouring, as it would be difficult to match the existing colour and height. Perhaps they just weren't too keen to come back for a small job.
I was thinking that it could be possible to just cut the rectangle of limestone immediately north of the sprinkler, redirect the piping to a new soakwell in the grass area, then try to re-lay the same slab of limestone like a paver. Not sure how feasible this is given that the underside of the limestone probably wouldn't be smooth like a normal paver.
This project has just been problem after problem!!!
You may want to bring this post to the attention of a couple of guys from the paving section on this site (CClarity, onc_artisan) I am just a DIYer.
cheers
Good idea.
You could try asking a plumber to put one of his drain cleaning machines down the pipe, could save having a patchwork in your paving
I've had a plumber round but he didn't have any luck, despite using all the high pressure gear.
Can you reach the other end of the stormwater system? Maybe you can put a hose up there??
Ed
2
Agreed. I just found out today the certifier has not given the final sign off.
26/11/2023
Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new…
17/01/2024
1
If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a…
