Avonview Lavender
1. Shade or a fair proportion of it.
2. wet feet
3a. Being planted too deep.
3b. Having mulch around the stems.
Get them in as much sun as you can. This can expose them to very low temps at night and that can cause some yellowing in them regardless.
Your soil maybe holding a heap of water with regular winter rains about. In these cases the roots become starved of oxygen and fungal diseases can take hold. In either case the roots die and the foliage is starved of nutrients.
When you plant something, take a look at the soil in the pot and where it is on the stem. When it goes into the ground, it has to be at that level still. Otherwise the soil gathers around the stem, collar rot sets in and that stops nutrients from reaching the plant. 90% of dead plants have died from this. they look great for a week or two, then just drop dead.
When you mulch, keep the mulch or pebbles pulled away from the stems to once again, prevent collar rot taking hold. (Not so important on bigger trees.)
other thoughts on the causes on this maybe using those bloody water crystals when planting. Might be holding too much moisture around the roots. (these are quite good in when using pots, however I don't don't use them.)
Using fresh manures when planting, burns the roots and stops nutrients and water reaching the leaves.
Putting fertiliser in the hole when planting. again, burns the fine feeder roots stopping moisture and nutrients from getting to the foliage.
Using cheaper products marked "soil conditioner" or "soil improver". Always use a certified organic soil, you won't go wrong
Thank you for your advice.
We did not put any fertilizers at all. All we did was just mulch it a little. Being winter in cold, cold Melbourne, there is a fair bit of rain now. Will take care not to water it too much. The plants are also always out in the Sun.
There were also weeds growing around the lavenders
I read that you can also put lime to it?
You are going to need a limey or alkaline soil. (Perth soils are good for something
That may very well be an answer for you problems. The garden area before planting (The whole area they are planted) would be best off having Lime and clay breaker dug through the structure of the soil. For now you will need to add lime around them. Easy to get from your local garden centre, however it may have limited results in this case. Give it a go. If it's no good, maybe select a plant that suits your soil type
