Paving
Looking for a recyled brick look paver but noth full thickness..I only have 75mm to play with and would like recycled brick look for under perogal...Giving up on timber as it too close to ground underneath which is tiled and currenly has batten and decking....
I need to get down to around 30mm
But thank you
https://www.permatimber.com.au
https://www.robertsons.net.au/rustic-thin-brick-pavers
https://3dstone.com.au/products/category/clay-bricks-tile-pavers/recycled-thin-brick-for-wall-floor/
The melange D stone looks like what i am trying to achieve..
Thanks again
3
I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.…
26/12/2023
10
As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide…
