hi we are installing a rainwater tank and pump to run our sprinkler system for our lawn. just wondering what brands of pump everyone recommends as we have had some conflicting advice on these?
thankyou
rainwater tank pump
thankyou
As far as pump brands go, a cheaper well set up pump will last longer than a poorly set up expensive pump but check what warranty applies to any pump you look at.
You also need to avoid two major but common plumbing mistakes by adhering to the following:
1. The suction hose must respect a straight length of preferably eight internal diameters at the pump's suction end and never ever allow the suction hose to connect to a 90 degree elbow at the pump.
Hose/irrigation line also loses pressure along its length. Depending on your irrigation design (if there are multiple sprinklers), you may need to connect the main line at 1/3 and 2/3 distance along the system to more evenly distribute the water.
The video below demonstrates pressure loss along a pipe.
https://www.youtube.com/watch?v=_hSL9_eo4n8
3
There is a difference in meaning between "available" and "connected" but the whole thing is ridiculous as the Victorian regulations bizzarely preference gas, not…
9/11/2023
7
Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I…
