Re: SOAKWELLS - How easy are they to put in and install ?
Page 5 of 7
Would be interested to talk to the user who built their soakwells out of tyres. Have a few questions for them before we embark on this project.
Hi All, I'm new to Home Reno.
Before someone else says it, DONT do it.
Your doing more harm than good. Chemicals that will leach out from the tyres will not be good for soil or the environment.
It seems such a good solution to drainage in an area that has very little access and isn't it recycling . Some of the local councils are even recommending it as an option.
To be perfectly blunt, they're wrong.
Fu help me out here :p
The problem is access to the area and volume of storm water. The storm water is from a large Box Gutter and a recently added extension to my home does not allow much access around the back of the house were the s/w is going, (I also have to consider a concrete pool that is in this area as well) I will have great difficulty trying to manouvering any size concrete s/w into this area. Due to the volume of water that comes from the box gutter, I think the alternative polypropylene options will not be suitable.
I'm interested but don't need them for another 8 months or so.
Can you tell me where you got them from?
Cheers
He is doing a soakwell after driveway has been laid and fencing is on.
Is that enough of a gap to install a soakwell and well that soakwell being so close to the boundary affect the fence and both our driveway.
300mm plus.
I need to install soakwells on the 18th/19th June and i was looking at doing it DIY through these guys:
http://www.soakwellsolutions.com.au/diy.html
My new house is in the city of cockburn and by their requirements my calculations show that i need 40 soakwell units!!
http://www.allaboutsoakwells.com/counci ... ckburn.pdf
This is going to blow my installation to over $2000. is this right?
The soakwells are poly ones : 400x450x600
Roof Cover: 335 m2
Does 40 sound right or is it overkill. from my understanding, i thought i only needed one unit per downpipe.
Is the figure higher because it is for concrete soakwells. Due to higher leaching rate of the poly soakwells would i need less of them?
Flotank, flow cell?
http://www.atlantiscorp.com.au/trade-products/flo-tank
It gets no better than these. They will hold several tonne so can go under a drive. They will also allow more water out into the soil faster than any other form of drainage.
I won't be having any soakwells under driveway.
Also, is one poly soakwell per downpipe enough?
However not many homes have that available.
Perth is in for a hell of a change.
We will see far less rainfall (estimated to be between 30% and 60% less than now in the next 15-30 years). However we will see far greater rainfall rates. The storms of March 2010 and Feb this year will become more common however they were at the extreme end of the scale.
So it makes sense to prepare for that and think ahead.
Soakwell solutions use a whole variety of different types of soak wells.
Atlantiscorp is the producer not the supplier of flo tanks to the best of my knowledge.
Of course who ever is cheapest, but it's that style of tank/well that is what is really needed.
3
I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for…
26/08/2023
6
That's a fantastic result! Happy you got it sorted out. cheers Simeon
