Backyard Thread - Pergola Up! - Finished!!!
Page 3 of 7
The bracing goes across this usually at 45 degrees to stop it flexing like a parallelogram.
Harditex (blueboard) is rated to act as bracing so should be ok.
I'm actually amazed that a council would allow the construction of timber framing that close to the boundary.
I know our council wont allow the construction of flammable materials that close to the boundary line without the installation of approved fire blanket. A construction like that would never pass our council.
Obviously different requirements in different areas.
Humble, that is the frame or studwork.
It looks sufficient for its use, I understand the bracing, councils are funny things. I have been to them 3 times for permits and been told all 3 times not required. Including 70sqm of decking.
That structure would definitely require council approval and wouldn't get it where we live.
Looks nice however.
As for council approval- the biggest concern they had was for my private open space. They declined at first but i managed to work something out with them and they were ok to attach a fully covered pergola after some persuading. Happy days !
With the roof being pitched so high however it still let's plenty of rain come in, especially when raining in hard at an angle. We do have intentions to add Cafe blinds to the sides however I don't think that it is possible to attach blinds to a raking face. One suggestion was to introduce a horizontal timber that would fix to house brickwork and across to the free standing wall. Does anyone have any suggestions or ideas of how we could achieve cafe blinds on the ends of the pergola ?
It looks great what you've done.
Plot ratio is always a concern as soon as you put roof cover on.
It's good when you can work with a council to find a suitable outcome.
As for the rest of it BCA is Australia wide (there are state and territory variations) therefore fire rating provisions apply.
However if there is a building permit then it's all approved, full stop.
Just for the record, in Victoria building surveying is privatised,even council surveying services are privatised, so council has nothing to do with building permits.
Well they somewhat do, they provide you information online in regards to whether you need one or not.
Example: http://www.brimbank.vic.gov.au/Our_Serv ... ion_Sheets
One way would be to have a level fascia on the sides, and then have the blinds atatched on the inside face?
The render looks fabulous. Have you installed the BBQ yet?
So as you can imagine, the backyard has come to a major halt. I've been stuffed around with a few landscaping companies also, failing on delivering quotes. Others coming up with ridiculous prices (ie - $17,000 for approx 49L/m of blockwork wall - heights vary from 200mm to 800mm).
We have come up with a new, more cost effective design for the back corner so hopefully this will reduce the amount of blockwork walls..
Any progress, i will be sure to provide some updates!
Bugger about the landscapers, is it worth finding a couple of brickies and seeing if they are up for a cash job? Odds are, most would have built something similar in their backyard.
Hope it all sorts itself out soon and everything works out.
Good luck!
*edit* - ok ive spoken to my bank - they have put a lodgement in but they said lodgements usually will have to be within 3 months of the purchase... i made the transfer 19/4/12. He said he will lodge it still, see how we go. However he did say the process would take 6-8 weeks until i might hear anything? Does this sound about right Bee?
Anyway, a few more pics from last weeks works. Garden boxs and new screen wall in. We are putting timber slats where the blueboard has been left off. Either a feature screen or water feature to be placed where the blueboard wall is.
We've changed the overall design also, see below for 3D image of how it is going to look! we are using a timber bench seat as the raised garden bed perimeter, with stack stone cladding below. Similar to the pic below. Ohhh and we are extending the decking all the way to the rear wall now, shes gonna be a big one!
More pics to come in a the next couple of weeks!
And the 3D design!
We are also looking at incorporating a bio ethanol outdoor heater and tv to the alfresco wall.. all in good time.. love to be done before summer!
I had a crack at building my first deck for the front porch (thanks to all the handy hints and tips on this forum). Turns out i SUCK at 45deg cuts on the mitre, but slowly working it out.
Here are some more progress pics!
And the deck slowly getting built, hopefully finish this weekend!
Actually just realised these pics dont show the deck picture framing im attempting.. will upload some pics when i finish off this weekend!
2
i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple…
17/09/2023
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
13/01/2024
Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some…
