My vegie garden and backyard
Page 8 of 14
You should also invest in one of these (ive got the red plastic one):
http://www.costanteimports.com/product. ... egory_id=8
Fredstar i have a food mill already which i used to puree the tomatoes, I think it's just a different design to the one you linked to.
Not sure if having them done up or not makes a difference - did yours still Pop and vacuum seal?
www.edenseeds.com.au !! They should get me through a few years worth of growing stuff all year around - very excited!!
I'm also looking forward to building more vegie beds and possibly garden beds and pathways over easter, although the garden beds out the back will also be mostly vegies too
I've just spent about $80 buying organic vegie seeds from I'm also looking forward to building more vegie beds and possibly garden beds and pathways over easter, although the garden beds out the back will also be mostly vegies too
Lisanne, bloody top job
Also, the area is about 4x10m so how many bags would I need??
1st is The Naked Farmer "Soil Activator" (In non marketing terms it's just bloody compost) very high carbon content which is seriously good
2nd says Organic but has about 5 trade marks on there for various chemicals that do stuff. Seriously why???? Not certified organic and highlights the point I often make, look for the Organic certification. This doesn't have one but they are allowed to say "Organic"
3rd has the all important BFA certification that ensures it doesn't have 15 different fertilisers, additives, chemicals that supposedly make your day pleasure not that don't workbut that we can do better with certified organic composts. Picture of a Frog makes you all warm and fuzzy about doing the right thing. A very powerful marketing tool
You just need the Naked Farmer of all those. Use Perlite if you are on a budget but if you can zeolite as well, that to is excellent to invest in
BAAG? Not sure.
You'd be needing 20 bags otherwise!
http://www.baag.com.au/?page_id=241
BAAG
http://www.baag.com.au/?page_id=268
Certified Organic Compost
100% Organic Compost
Certified Organic Compost contains plant matter that has been decomposed naturally. It is rich in nutrients and helps improve impoverished soils, as well as helping to retain moisture. Certified organic compost is suitable and safe for use with natives.
Lisanne will you be refreshing existing beds or creating new ones?
Refreshing really, I want to refresh all the soil I got brought in originally from BAAG when I moved in, now I want to turn it into proper garden beds so I just want to improve it.
I'd be dumping 1/2 a cube of compost into a spot like that. That is half a trailer load. Who in Vicco does bulk compost that are cert organic?
BAAG? Not sure.
BAAG? Not sure.
That's what I was starting to think actually, might be cheaper! I can't tow that much but other family members can, now to see if they will....
Tray 1
Beetroot - Melbourne early slowbolt Beetroot - Melbourne early slowbolt Broccoli Albert Brussel Sprouts - Long Island Cabbage - Savoy Drumhead Cabbage - Savoy Drumhead
Beetroot - Melbourne early slowbolt Broccoli Albert Broccoli Albert Brussel Sprouts - Long Island Cabbage - Savoy Drumhead Broccoli Albert
Tray 2
Cauliflower - All year round Cauliflower - All year round Leek - Carentan Leek - Carentan Onion - creamgold Onion - creamgold
Cauliflower - All year round Leek - Carentan Leek - Carentan Onion - creamgold Onion - creamgold Onion - creamgold
Tray 3
Shallots - Straight Leaf Shallots - Straight Leaf Spinach - Giant Nobel Sugarsnap Pea - Climbing Sugarsnap Pea - Climbing Onion - creamgold
I hope they work!!! I've never planted from seed before
Love the egg cartons for your seed beds.
I was thinking of buying one of those mini shade house thingys……well done Lisa!
Thanks Michelle! I got the greenhouse from Erin and Aaron. I hope the egg carton theory works! Like I said I've never done this before so it's a big learning curve!!
It will work….its been done for a very long time, just make sure you keep them watered.
Oh and by the way, you can plant into the other side of the carton, or just cut that side off.
5
thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you…
21/06/2023
10
It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils.
11/08/2023
Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right…
