I have started digging up a plant that I suspect is growing into my drain and causing it to fill up then drain away. Not completely blocked yet. I dug down to the clay layer, but I suspect the drain is too deep for me to reach easily. Should I just chop of the plant root at the clay layer and fill the hole? I suspect it will die like that, as it will have no sunlight to encourage new shoots. Or should I keep digging and try to find the drain?
Thanks
Roots blocking drain
Thanks
I have seen tablets that you can flush down a drain to kill off roots as well;
https://www.bunnings.com.au/drain-clean ... lsrc=aw.ds
See how that goes first?
Available at Bunnings.
It's basically just copper sulphate.
Drain Clean Root Control.
Tnx alot.
i have an issue with a client of mine, i'll check your solution.
5
Thank you. I will look at trench less pipe replacement.
16/04/2024
I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But…
27/06/2023
4
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
