Pump - Underground Water Tank - Noises ?
I have a great Underground water tank. It has a pump to access water.
We have been away and I've noticed a ticking - like a clock coming from the pump electrical area.
Any ideas on what it might be - is it a common thing ?
But - its back today.
Might open the box up and have a look.
With the symptoms described, the pump's capacitor would be the next check. They are easy to remove, check and also cheap to replace.
You can't go wrong when installing a new capacitor, just make sure you are sold the correct one. It will cost about $25.
But - will still need to fix.
Not sure why the thing clicks - but it might be pressure from full tank ?
Will post outcome.
http://www.irrigationstore.com.au/Library/Image/Valves/solenoid.jpg
The black bit - with the two wires.
AND - not like the "plastic" above ground tanks either - as I understand it.
Yes - it does switch to mains when low. Only ever happened once in the past 5 years.
But - yes - it is part of that set-up. It screws into the system.
It has proven very useful - excellent pressure from pump - better than mains. I use it for gardens too.
Funny - I've never really looked inside the main "box" but there's a "reserve" battery - apparently I'm meant to replace it every few years ...
So I have done this now ...
If I put the wrong one in what could happen ?
Also - why does it click - and then not click. It might click for a few hours - then not for a similar time.
10
That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor
23/07/2023
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
15/01/2024
7
Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It…
