Media Room.. cables in wall cavity
Is there any codes/standards to consider when running speaker cables (from wall mount tv) through the wall cavity and ceiling to where surround sound speakers go and a hdmi cable from amp to tv via the wall cavity ?
I'm curious if there is any fire risk basically or easy for us to do ourself.
... you must be a licence delete tri ain with the correct endorsements on your licence to work with coax, phones and data cables.
Only a licensed electrician can work with coax and data cables? Evidence of this, please?
My bad, no mention of coax but data and phones are definitely covered by the legislation
http://www.acma.gov.au/Industry/Supplie ... quirements
Just surround sound and TV cables.. hdmi.. so we should be cool putting them thru the walls
You don't need to be a licenced electrician. An electrical licence on its own gives no authority to work on telecommunications cabling. You need an ACMA cablers licence which is another qualification.
I'm pretty sure coax was also included in the definition of "customer cabling" recently as well (in the last few years). But your ACMA open licence is no longer sufficient for data or coax cabling.
So to clarify, to work on standard telephone cabling an ACMA open cablers licence is a legal requirement. To work on data you need the ACMA licence with structured cabling endorsement. To work on coax you need the ACMA licence with coax endorsement. Same deal with fibre optic.
I have no doubt there are plenty of electricians and technicians running around doing unlicensed telecommunications cabling. Probably plenty of completely unqualified DIYers too...
As far as I know speaker cables and video cables do not require any particular licence, however they still need to be run with separation from power cables for safety as they would be classed as Extra Low Voltage electrical cabling.
Yes you are quite correct, I guess I just associated that type of work with electricians, my bad. I am sure there are other registered cablers around who have a non-electrical background.
The short answer is No, there is no current regulations for a licence requirement for speaker cabling, however there is still a long list of requirements you need to follow as it is still classed as cabling works, mainly separation from power cabling, do not run it inside the same conduit as any power cabling, keep it away from any power terminations, be it switches, GPO's, light fittings etc and you should be fine.
5
your always amazing and lifesaver Simeon . Great thanks a lot >
23/02/2024
3
Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you…
