I’m doing some renovations in my house and I would need some advise.
I have an atrium that used to have a small pond and a fountain. I decided to get rid of both and after removing all rocks/etc we found out that around 60% of the area is in concrete and the rest is ground.
Dimensions are around 250 x 180cm - the height of the existing concrete is around 8 cm.
I would like to have a concrete floor there so I can put a sauna instead. I’m not planning to put tiles, the sauna will rest on the concrete and I'll put little stones over the remaining area.
As you can see from the image below, the existing slab is not leveled (2.5cm "missing" in the middle).
There are a couple of holes and a drain (I'm not sure if it still works) -
Anyway I think my options are basically:
1/ lay a new concrete slab that covers the whole area
2/ lay a new concrete slab on the new area first then put an overlay on top of the old one
In case of option 1, I believe separation will be needed to avoid binding. I do not want the floor to be any higher than what it is currently so I think this option won't work for me.
For option 2, my questions are:
1/ Should I leave a gap between the concrete and the walls/existing slab? If so how much gap is needed?
2/ Should I use a 'plastic layer' to protect the slab from humidity or should I leave a hole as with the other one?
3/ If I make that new concrete slab leveled, any potential issue putting an overlay over the old one?
Any comments/help appreciated.
Cheers.
B
