How to fix internal wall hairline cracks
There are lots of hairline cracks on internal (plastered) walls and looking for the best way to fix.
When I accidently knocked into one wall, I noticed the plaster under the paint had a white powder texture when I rubbed my finger over it. Not sure if this is normal or not. I've not come across it before.
I get the impression the previous owner did a quick patch job and perhaps the finish was painted over too soon? Or a sealant missed out? Stabbing in the dark here!
I was thinking of filling in the (very faint) hairline cracks with spec, putting some kind of seal over the wall (what?), and then painting.
Alternatively, it seems I can also paint over with some kind of flexible paint that will fill and paint in the one go?
I did paint over one wall with paint, a couple of coats, and can now only see a few of the hairline cracks.
But as there is so many of them (a big house) was wanting a longer-lasting solution.
Sorry if this sounds a bit dense, have spent ages googling, and still unsure.
Has anyone any suggestions of what I can try to fix it up?
Thank you!
If the rendered wall is painted too soon after being plastered then hair line cracks will appear everywhere looking like crazy paving (or like crocodile skin) .
When the wall is repainted these type of hair line cracks should disappear.
Plaster cracks that look like zigzags (following the brick mortar joints) are more likely to be due to structural movement.
When I built my first house (about 40 years ago) I was told not to apply the final coats of paint until 1 year after the walls were plastered. Only to initially apply a clean up coat of paint to seal the walls.
I ignored this advice and painted the house throughout immediately and sure enough all the walls looked like crazy paving after about a year.
After 2 years I repainted the whole house and the crazy paving hair line cracks disappeared and never returned.
I think I'll repaint and see how it goes.
Yikes! Totally deluded by the planning and building process
You will need to identify the causes of brick cracking unfortunately masonry walls in perth are not reinforced. More info & pics required
Where is it build,are the internal walls clay V or H cored, where are the cracks located, length & height of wall, etc,etc
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
18/01/2024
1
Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions!
23/12/2023
Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the…
