Plug screw holes second hand colorbond
Has anyone done this successfully - would welcome suggestions as to what to use to both withstand the weather and also disguise the fact that it is recycled tin.
3
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
13/06/2023
1
it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you…
27/07/2023
5
I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible
