There's something wrong with this roof...
My garage roof-line:
http://www.flickr.com/photos/tapd0g/849 ... hotostream
Neighbours' roof-lines:
Am I imagining that the roofs are uneven? Is it normal? The villas are mid-nineties build and on slab. The soil is clay, reactive and we have very poor drainage. A drain has been put in (twice) to aid drainage but hasn't done much.
Edit post to take out [img/] code: 11:44 by Charlotte1
No, they are uneven.
Some roofs do sag a bit over time so I guess in a cheaply done roof this would be kinda normal but certainly not one that I would be happy with.
I don't think the reactive clay has any bearing on your roof unless you have massive cracks in the walls showing a lot of movement.
It is more likely as a result of maybe one or two faulty trusses that have sagged or bent.
By the way the img code is what you use to display the photos here as a image not a link to another site which is a PITA.
Go up to share above the photo and click BBcode then copy the code that appears - http.www etc
Paste it here in this thread. I just removed the other line of code and left [img]...[/img]
Stewie
Looking at those skylights though I'm wondering if whoever cut those into the roof also cut through the trusses - a big no-no.
Only a closer look by a carpenter or builder would be able to tell us that though unless you get up there and take a few photos yourself and post them up here for us to comment.
Stewie
4
I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag.
24/08/2023
Hi Everyone I learned something this week that I thought would be worth sharing. In NSW a lot of developers of subdivisions put covenants on the land which normally…
26/07/2023
6
there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to…
