Building ForumDIY, Home Maintenance & Repair
Cracked Render to Lightweight Wall
Hi all,
I have a lightweight, two storey apartment, and I've noticed that the render is cracking in some areas on the outside.
Is this an automatic cause for concern, or is cracked render a fairly normal thing that just requires some gap filler to maintain general waterproofing?
http://www.flickr.com/photos/93219019@N02/8474733219/
http://www.flickr.com/photos/93219019@N02/8474732925/
Any help would be appreciated!!
Thanks,
Jess
Your pictures don't appear.
Do a search here on how to post pictures.
Stewie
Ah you're right - I"m not very forum-savvy, though I did try to do exactly what the instructions said! Note, I've changed it so that the links to the Flickr account are just there now, that oughta work.
Thanks for pointing it out.
I cant offer a solution but from your first pic it seems the wall lining is coming away from the structure and the problem will be how to re-fix it and patch without it standing out like the proverbial.
Good luck
How to fix gaps, nail holes, cracked wall/paint from skirtin
Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the…
23/07/2023
3
Fixing cracked stormwater PVC pipe
General Discussion
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
9/05/2024
1
Tiles cracked anyway to fix?
Outdoor Living
how on earth did that happen? the tiles need to be replaced, I’d be checking the concrete slab too, either tile needs to be loose or the slab cracked I would think
