Hi, I recently bought a 10 yr old house. I have noticed a series of cracks both on the external walls and some on internal plaster boards. There seems to be a general pattern to all of them (most of them are around the rear part of the building) I suspect that it could be structural specially since there is some heavy earth digging happening to lay some train tracks nearby (20 mts). I need some professional to have a look and give me remedial advice. Does anyone offer such a service ? Any info will help
Thanks
Vishal
Cracks in Walls
Thanks
Vishal
Thanks
Vishal
Thanks
Vishal
Seriously doubt digging 20m away would cause any major structural damage. Digging 1m away maybe. You would get a lot more help and advice on you problem if you were to post some pictures or at the very least explain what the cracks look like, ie size of crack and length etc.
The crack on the left external wall runs from the ground up to the ceiling through the bricks. It is only about 3 - 4 mm wide I would say, then roughly around the same place on the interior there is a crack opening up in the roof and side wall plaster board (these had been painted on to conceal them) then on the other side of the external wall (opposite side) there seems like a wider crack that runs next to a door frame making it look like the entire wall is leaning away from the building. On the whole if one links all the cracks it looks like the rear of the building is sinking !!!
Also has anyone heard of URETEK (http://www.uretek.com.au/pages/home.asp) apparently they specialize remedying in this kinds of issues
Yes, i have heard of them. Maybe give them a ring & see if they have an engineer that can do diagnostics? It does sound like you've had some subsidence & perhaps need underpinning.
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
4/10/2023
5
Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,…
