I plan to put up 3 acrow props on the inside of the floor to wall windows with the base plates attached to a timber base and structural timber attached to the top plates. the acrow props will be around 900 to 1000 mm apart so I can provide support under 4 ceiling joists which are spaced about 600mm apart. The structural timber will sit under ceiling plasterboard. I will probably brace the acrow props to each other.
Even though I have tentatively spoken to structural engineers, I am not going to engage one for this temporary measure as acrow prop support should far exceed the original load support by steel post before it rusted. The acrow support was suggested by a builder.
I would appreciate any advice or comments particularly on the proposed temporary measure, the type or specs of structural timber I should use, is it possible not to damage the plasterboard ceiling,
I may even decide to replace the post myself if it is not beyond my skill level but there are 2 month delays to get plates welded to SHS steel and to get it hot dipped galvanised. I also have to remove any rusted steel from concrete slab (post was concreted in) and repair concrete to provide a base for new corneer post.
